t-lok broke
Guest
Posts: n/a
lol, it would corner like sh*t if you welded the spider gears together. good for straight line, though.
maybe you should call the place you ordered the tlok from and invest in an upgrade, while u are at it? ive heard too many people say the tloks are breaking...on not so much over stock power, either.
and i OWN a tlok!
might be worth it to spend the couple hundred extra bucks for a detroit truetrac, or an eaton lsd...
and i OWN a tlok!might be worth it to spend the couple hundred extra bucks for a detroit truetrac, or an eaton lsd...
A t-lok can be rebuilt for cheap. It's nothing but a stack of clutches, and if you get them to remove one of the steels, then you can have 1 more clutch in it.
It's normally done [S][C][S][C][S][C][S][C][S][C][S] (C=clutch S=Steel)
they can do it [C][S][C][S][C][S][C][S][C][S][C]
There's a shop in Houston that did mine like that, it actually made a difference.
