underdrive pullies need some advise
i have done alot so far to my 1995 3.8 now i wanted somes underdrive pullies but my car draw alot of power from the alternator cuz of the suff i have hooked up to it so i installed a 330 app alt now if i get pullies will this effect my battery power and if not weres the best place to get these and which kind do i get......thanks
well.. they make kits that you also change the alternator pully.. ..
a underdrive pully makes your belt turn slower... but by making your alternator pully smaller as well, your putting the alternator to crank ratio back to where it was originally... so you will still get the same power out of your alternator as if you wern't running pullys..
i have 2 amps,many strobe lights and neons,a cop loud speaker ,air horns,playstation but i have a yellow top battery and 330 amp alternater do u guys think it not worth it to get pullies.and someone mention about changing the altanator pullie where would i get that
Guest
Posts: n/a
here i come to save the day!
1st of all, damn, those are some accessories. it could either be really cool, or really whack, depending on how you pulled it off.
that being said, to your question: goto vmptuning.com. justin sells a 3 piece ASP brand pulley kit that comes with an underdrive crank pulley, an underdrive water pulley, and an OVERDRIVE alternator pulley, and the correct size belt. i have this exact set up, and it works beautifully. quicker revs, a little more on the top end of things, quick install...and for you, it creates no extra strain whatsoever on the alt. pulley, it overdrives it, so it counteracts the effect from the underdrive from the rest. youll be good, even with a system, esp. since you have such a large amp. ive never seen one that is 330amp, christ. i wanted to get a cool chrome 220 amp one. i even saw one in ford blue once, but it didnt look all that well done.
ok, gotta sleep, too many sedatives tonight. peace to all!
