Code IMRC1M(V)????
Old Sep 30, 2008 | 03:01 PM
ssnova2004's Avatar
ssnova2004
Default Code IMRC1M(V)????
Hello all newbie here and iI have a question for all u Mustang Lovers out there...My girls car check eng light came on and she had it checked and the told her that it was reading a code as follows IMRC1M(v).....Can anyone tell me what it means or what I can do to fix it so we can get the check eng light off. Once again thanks all for ur feed back.
Old Sep 30, 2008 | 03:52 PM
LilRoush's Avatar
LilRoush
IMRC are intake runner controls on 01 to 04 cars.
What was the OBD II code? Should be P.......
Old Sep 30, 2008 | 03:54 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
That's not a code, CEL codes are displayed as P0000, the "P" followed by 4 digits. Is the car acting funny in any way?
Old Sep 30, 2008 | 05:41 PM
ssnova2004's Avatar
ssnova2004
not sure about the P....///////but the guy did mention something in regards to it been a stuck valve (open) in the intake runner controls on cyc 1side...will get the p.... # and post ...thanks for all so far guys
Old Sep 30, 2008 | 05:51 PM
ssnova2004's Avatar
ssnova2004
and no the vehicle seems to be running fine...mind u this happened when i had true dual exhaust put on w/flowmaster.
Old Sep 30, 2008 | 06:23 PM
RyansQuick6
Reverse Gear Member
Well it's vacuum controlled so it is possible that a hose going to it became damaged
Old Sep 30, 2008 | 07:01 PM
ssnova2004's Avatar
ssnova2004
ok sounds good to me.quetsion...if its a possible hose where at in the eng should i look?...any pic's or descrptive will be helpful...thanks again all
Old Oct 1, 2008 | 04:37 PM
ssnova2004's Avatar
ssnova2004
Would anyone have a pic and or a description of what, where the intake runner controls are located? Thanks in advance
Old Oct 1, 2008 | 05:08 PM
RyansQuick6
Reverse Gear Member
look at the back of the lower intake, two little vacuum actuators on each side.
Old Oct 1, 2008 | 06:25 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
they break alot. that could be your problem
