don't push brake to hard, or you'll screw pads too. hold the brake just enought so that the car is not moving. if only one wheel smokes then you better stop birning out
he's in a 6, only one wheel is on gonna spin. Your front brakes pretty much do all the work anyway, so you hold the brake just firmly enough to stop them from rolling and watch your rpm's so you don't get out of 1st gear. Also watch you temp, if you do it for too long, your engine temp will rise pretty quick and you should let out until it cools down.
