need help with engine
ok well i have a direction i want to go with me engine build but i need help putting the parts list together. I have thought about it and i want to be able to say "look what u can do with the 3.8" so i am not wanting to do any boring or stroker kits. I need a setup that will hold 15-25psi and up with a twin turbo kit. I have the windstar manifold on the current engine but the new one will have the f150 mani. I really would like to see this done in a year or so as the money comes for it.
no rush with the help but i would like to start the parts list. I would like to get all available forged parts and a nice mean cam but will need to get more of an idea of the entire build.
well i would have to get stage 3 and i will not need the ported upper. plus this is only the upper engine i will also need everything else. this is all going on a 3.8L block on an engine stand so im building it from the ground up.
Stage 3 even better. I dont believe they sell the parts seperate though. Only chance of getting that is Ebay or something.
Here's what I'd do:
From SSM
3.8L Forged Internal Kit from - $1625
Windage Tray - $125
Billit Harmonic Balancer - $425
Stage 3 Powerpack - $2700
From Spec
Spec Aluminum Flywhell - $399
Spec Stage 3+ Clutch - $529
From gforcetransmissions
T-56 GForce Built Transmission - Call for price (don't know about belhousing though)
8.8" Rear w/Detroit limited slip differential and 3.55 gear ratio = approx $1500-1800
Whatever type of turbo set you're looking to run = approx $7500
In short, I hope you stumble upon a lot of money because you still need to upgrade the entire fuel system, ignition system, and your own personal tuning software (a tuner won't cut it here).
From SSM
Windage Tray - $125
From Spec
thanks thats what i was looking for.. i will be able to cut cost on some of those but thats around the prices i am willing to spend. Like i said this will be through a year or so and the turbo kit not that much i am parting the kit together myself using and deals i come across. The tuning software i most likely will get from diablo sport but i am the vp of inline performance inc. and we will be opening a "shop" online to start and may carry our own line off tuners from a new company..
