starting problems
Old Oct 9, 2008 | 08:51 AM
Richbrad08's Avatar
Richbrad08
Default starting problems
i have been having some hard time starting my car. like when i go to start it go to crank then just die on me....so i took the battery cable off and replug it on and it starts. then after 7 times of doing that i got fed up with it when it did it the eight time and bang on the steering wheel and the needles on the gauges went all the way up just like it did when i took the battery off. then crank. so does anyone have any suggestions one what could be causing it...
and twice this month i have had some issues with the theft light...like i was driving and it was blink rapidly
Old Oct 9, 2008 | 03:17 PM
Richbrad08's Avatar
Richbrad08
bump...i think it a wire should i take it to ford?
Old Oct 9, 2008 | 03:28 PM
mustangman02232's Avatar
mustangman02232
clean the terminals and contact points, and have the battery tested
Old Oct 9, 2008 | 05:57 PM
Richbrad08's Avatar
Richbrad08
I noticed now the postive and negative battery cable are lose but should that cause the problem b/c i hit the steering wheel and it reset everything... it a new battery
Old Oct 9, 2008 | 09:18 PM
cuban tech's Avatar
cuban tech
a new battery doesn't always mean it's a good battery there could be a internal short. And i would clean the terminals and insure they are tight.
Old Oct 9, 2008 | 10:00 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Have you checked conections to the starter or alt? Sounds like a loose cable to me.
Matthew
Old Oct 9, 2008 | 11:06 PM
Richbrad08's Avatar
Richbrad08
not yet i havent had much time to look at my mustang...been really busy just got enrolled in collage...have 2 jobs interviews...been taking my g/f to the doc b/c she pregnant with my baby boy... lol im going to try to look at it. so the starter is in the steering wheel? i'l check the cables to the alt.... and buy new cables for the battery.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
