4.2L help
Old Oct 9, 2008 | 05:40 PM
njdanmustang's Avatar
njdanmustang
Default 4.2L help
Ok I did research ect.. so many mixed options so I thought I would get a clear answer.
What EXACTLY do I need for my 99 3.8l v6 to make it a 4.2L and what all needs to be done.
Thank you!
Old Oct 9, 2008 | 07:34 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
Thank you!
the easiest way is to find a 99+ f150 shortblock....
but you could change all the internals (crank,pistons,rods)
Old Oct 9, 2008 | 07:54 PM
95redv6stang's Avatar
95redv6stang
So, the 99+ Mustang heads and such bolt right on too the F-150 shortblock?
What are the gains with just the F-150 shortbock? (with a 99 Mustang, not mine)
Old Oct 9, 2008 | 11:14 PM
03sixbanger
Ryan's Backup Mod
yes the heads will bolt on....and im not sure of the number gain but it is a noticeable difference
Old Oct 9, 2008 | 11:23 PM
95redv6stang
Ok, and does it use the same Computer or the F-150 or does it need a tuner?
Any good links out there on the swap?
Old Oct 10, 2008 | 09:24 AM
03sixbanger
Ryan's Backup Mod
you will need a tune...trust me. i learned the hard way
Old Oct 10, 2008 | 01:38 PM
njdanmustang
So, I just replace my shortblock with the f150's and get the tune?
What else would you recommended switching, say if I could find a complete f150 motor?
Old Oct 10, 2008 | 02:11 PM
RedStarBelgrade's Avatar
RedStarBelgrade
BEWARE OF THIS SELLER. He will sell you junk and call you an idiot for falling for it. Know what you are buying! Admin
I've been asking this question a lot lately. And from what I heard you can only get a 4.2 crankshaft and that will make your motor 4.2...or I might be wrong!
Old Oct 10, 2008 | 04:38 PM
l_shizzle_l's Avatar
l_shizzle_l
Yes, and you also need a 01+ 3.8 oil pan, 01+ harmonic balancer, and 01+ flywheel(or a neutral balanced one). Reason being that the 99-00 3.8 motors are balanced on the flywheel and harmonic balancer, 01+ 3.8 & 4.2L's are balanced on the crank which require different flywheel and harmonic balancer. The oil pan is needed to clear the taller mains of the 4.2L block.
The shortblock is really all that is useful from the 4.2L motor. The cam is less aggressive, and the intakes are way too tall to fit under the stock mustang hood. I think the heads might flow slightly better, but i honestly don't remeber.
Old Oct 10, 2008 | 04:49 PM
03sixbanger
Ryan's Backup Mod
i thought the 4.2 cam was a little more aggressive
