side badges
Old Oct 18, 2008 | 09:02 PM
Zach333's Avatar
Zach333
Default side badges
a few questions on how to paint my side badges...
#1 how do you remove them and still be able to reuse them (so not messing up the sticky part)
#2 what are the steps to painting them properly so it wont peel
Old Oct 19, 2008 | 12:12 AM
jthorn9's Avatar
jthorn9
The Godfather
Well there is no easy way to remove them and not take some of the adheasive with them, however Home Depot, and other places, sell a can of spray on tape (if you will), that you can spray on a surface and make it adhear to anything, I've used it and it works fairly well. To take off the badges use an old credit car, and just work it, you can get a hair dryer to heat it up a bit to make it a little easier, but a little elbow grease is all you really need.
Sanding/stripping old paint
Primer
Light Sanding (1000 grit)
Primer
First Coat
Second Coat
light Sanding (2000 grit)
Third Coat
Final Coat
Clear Coat
Final Clear Coat
That's a good example of how to paint most parts with a gun, but for side emblems, all you really need is some good model paint, that stuff is beast, and will do what you need.
Old Oct 19, 2008 | 01:10 AM
3.8_Special's Avatar
3.8_Special
A good gasket sealr/ RTV works very well too.
Old Oct 19, 2008 | 01:00 PM
Zach333's Avatar
Zach333
model paint like you use to paint model cars?
lol prolly sound retarded right there
and then a clear coat?
if i did that i wouldnt need to sand??
Old Oct 19, 2008 | 05:01 PM
jthorn9's Avatar
jthorn9
The Godfather
Depends on the look you want, but model paint (the good stuff) is decent good quality paint. If it starts to wear or fade, it's cheap and easy enough to quickly fix, but yes, model paint as in the cars. Also, depends on what you're painting exactly, if you're going to repaint the whole thing, then I'd lightly sand the emblem to remove red/white/blue paint, and to roughen up the silver/chrome so that it will hold a new color. Don't forget to prime them, if you don't I promise you the paint will not stick.
Old Oct 19, 2008 | 09:31 PM
Zach333's Avatar
Zach333
1000 grit sand paper work then??
Old Oct 19, 2008 | 09:56 PM
mustangman02232's Avatar
mustangman02232
autobadges.com FTGDW!!! (where the fugg has he been?)
Old Oct 19, 2008 | 10:05 PM
Zach333's Avatar
Zach333
i dont even understand those lol what is 232?
those arent my style... i dont find them too special to be honest ha
Old Oct 19, 2008 | 10:43 PM
torchred02's Avatar
torchred02
232 is your engine size
Old Oct 19, 2008 | 10:54 PM
sIx's Avatar
sIx
232 would be the 3.8 (which as torchred said, we have) a 302 is a 5.0 etc...
