line lock
Old Oct 23, 2008 | 12:40 AM
Red Beast's Avatar
Red Beast
Default line lock
does anybody know were i could buy a line lock from and about how much it costs, i want to do some sick burnouts but obviously it would really help if i had a line lock. would it even be worth putting one on an 05 mustang? im not sure how much torque i need to pulling to be doing some nice ones.
thanks
Old Oct 23, 2008 | 12:42 AM
haystackstang's Avatar
haystackstang
slp make one for mustang not sure years tho
Old Oct 23, 2008 | 06:16 AM
moontang's Avatar
moontang
you come with one stock......just salm your foot in the gas and brake at the sme time.......
see
http://www.youtube.com/watch?v=FI7XuRqloyM
Old Oct 23, 2008 | 10:41 AM
mustangman02232's Avatar
mustangman02232
say buh bye rear rotors, pads and calipers
americanmuscle.com has on i believe
Old Oct 23, 2008 | 10:47 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
www.thunderracing.com
That's where i got mine, and now I can't find it anywhere in my house lol
Old Oct 23, 2008 | 03:17 PM
psyviperx's Avatar
psyviperx
thats because its in my shed with my windstar intake...
Old Oct 23, 2008 | 04:39 PM
RyansQuick6
Reverse Gear Member
at least they'll be getting used lol
Old Oct 23, 2008 | 05:12 PM
ramoyer1's Avatar
ramoyer1
lmao he took it and you didnt even know!!! you guys need to put them parts in the shed to work or something.
Old Oct 23, 2008 | 05:43 PM
.boB's Avatar
.boB
A line lock is a very simple device. It's merely a hydraulic control valve. Energize the solenoid and the valve closes. It really is that simple.
Most newer cars have two front brake lines directly from the MC, instead of one MC line that branches near the left wheel well. Since there are two lines, you need two solenoids. Both can - and should - be controlled by the same switch. The fancy kits designed specifically for the 05+ Mustang include special lines and brackets to make installation easier. But it's still the same concept.
For a cheap quality part set, buy two kits from Summit Racing. Then use your own skills to fabricate the lines and brackets to make it all work. Not difficult, certainly not rocket science. But time consuming.
Old Oct 23, 2008 | 08:24 PM
RyansQuick6
Reverse Gear Member
For a 94-04 you only need one solenoid, it's easy, the hardest part is bleeding the entire system. I'd recommend installing, bleeding and then going and getting your brake system flushed with all new stuff. You'll need a flare tool and a tubing cutter, and possibly some extra fittings. I'm gonna buy ANOTHER line-lock tomorrow and install it, so I'll have more details once I get it done.
OOOH, things are different if you have that ABS crap. I'll look at the Bullitt tomorrow to see what's needed.
TCStangerv6
Oct 11, 2015 05:57 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Sep 25, 2015 06:58 PM
