upper/lower control arms
Old Oct 24, 2008 | 10:48 AM
DreamBMC's Avatar
DreamBMC
Default upper/lower control arms
I couldn't find an answer on the internet so I have to as here?
What's the difference between upper and lower control arms? I know they give traction and plant yur tires to the ground but can you have just upper or just lower and befine or do you need both?
On AM there's two brands, J&M and steeda
Which brand would be better and work fine
Old Oct 24, 2008 | 02:06 PM
mustangman02232's Avatar
mustangman02232
ones on top ones on the bottom
autbadges.com has em as well, hes got MM and steeda, LCAs will make the bigger differance but you will see good gains from both
Old Oct 24, 2008 | 02:38 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
im going with upr. MM is probably one of the best brands but i just can afford them. so im hoping to see a little more traction at the track with the upr's
Old Oct 24, 2008 | 03:28 PM
LilRoush's Avatar
LilRoush
Do lowers..... unless other major work is done, uppers won't do much but bind.
MM are top notch, Steeda is good as well. Several companies make good control arms.
Old Oct 24, 2008 | 03:53 PM
03sixbanger
Ryan's Backup Mod
have you seen the metco's matt?? now those are some nice control arms
Old Oct 24, 2008 | 05:20 PM
LilRoush's Avatar
LilRoush
I haven't. I've got Roush and Southside Machine LCAs.
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
