boost gauge
Old Oct 27, 2008 | 10:14 PM
DreamBMC's Avatar
DreamBMC
Default boost gauge
preparing for my m112
ordering DTT, 4.10 gears, MM CC plates and lower control arms in 2 weeks
then its time for the m112 to come. i am researching and learning about the m112
and all of its components. is just a cowl hood and boost gauge all thats needed to
work with the m112? how does the boost gauge work, what does it show? how do i know
what # of boost gauge to get. I want to get two other gauges also for just my personal wants, what are two other good kinds. I was looking at the wideband, what does that show.
what is a good brand of gauges also. www.speedofsoundllc.com is right now the street from me also so ill probably hit them up sometime too
Old Oct 27, 2008 | 11:13 PM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
go with autometer gauges. get a boost, wideband, and oil pressure
the wideband shows you the air/fuel ratio
Old Oct 27, 2008 | 11:32 PM
DreamBMC's Avatar
DreamBMC
thewideband is a wideband regardless right? but with the oil pressure and the boost, whats the different psi's mean- i know its pounds per square inch- isnt 1 psi=10hp? but how much psi should i be looking at for the two?
Old Oct 28, 2008 | 12:42 AM
3.0Taurass's Avatar
3.0Taurass
Oil pressure has nothing to do with horsepower.
Boost is measured in pounds per square inch. Regular atmospheric pressure is around 15 psi. Meaning that for every 15 psi of boost you run on the engine you basically double the power output.
Old Oct 28, 2008 | 12:51 AM
mustangman02232's Avatar
mustangman02232
theres an oil preasure guage on the dash, and while it may not be 100% accurate, you will know if something goes wrong, id do, if its an auto, id actually go with a tranny temp first, if its a 5 speed, you should be fine with just the boost/AF
Old Oct 28, 2008 | 02:35 AM
cobra232's Avatar
cobra232
4.10's are too much gear for a positive displacement blower setup. 3.45's are ideal foir a M112 setup.
3.73's max
Old Oct 28, 2008 | 06:11 AM
DreamBMC's Avatar
DreamBMC
yeah i looked around more and ill just go with the boost and widebandA/F. but how do i know how much psi to go with with buying the PSI gauge, its goes from like 30 to 35 to 60, whichone?
Old Oct 28, 2008 | 06:12 AM
DreamBMC's Avatar
DreamBMC
i havent heard of that now but ill look at it more
3.73's max
Old Oct 28, 2008 | 06:41 AM
03sixbanger
Ryan's Backup Mod
the stock gauge reads normal if you are above like 6psi. if running a forced induction setup, an oil psi gauge is not a bad idea
3.73's max
+1. i have 3.73s and they are just right but i wouldnt go any lower
most boost/vacuum gauges will show from i think 30psi to 0 and from 0 to 30psi
Old Oct 28, 2008 | 08:37 AM
DreamBMC's Avatar
DreamBMC
Derrick, so you think 4.10s are too high?
Does the cobalt series of nexus look good? I just don't like how bright they are, but ill just get that like $350 wideband A/F and a 30or30psi boost gauge?
By the way, ill ask you 1 or 2 more things about the m112 and if I need to get anything else besides the kit and the gauges, but ill ask more about that when it comes to the time in march
