Performance Mods
Old Nov 4, 2008 | 08:02 AM
Dipper2491's Avatar
Dipper2491
Default Performance Mods
What are the best mods, upgrades, and improvements to the engine and/or car to maximize rwhp, torque, and acceleration
Old Nov 4, 2008 | 08:11 AM
Goodrip's Avatar
Goodrip
https://mustangforums.com/forum/v6-1994-2004-mustangs/427899-tech-3-8l-modifications-and-getting-started.html
Good Luck
Old Nov 4, 2008 | 02:14 PM
mustangman02232's Avatar
mustangman02232
blower, turbo, or nitrous
Old Nov 4, 2008 | 03:08 PM
jthorn9's Avatar
jthorn9
The Godfather
Accelleration: gears and a limited slip differential
Torque and HP: Supercharger or turbo charger and N2O
Torque: Stroker Kit
HP: P/P upper/lower intake and heads along with a cam swap
Old Nov 4, 2008 | 03:21 PM
ByPopularDemand's Avatar
ByPopularDemand
If your trying to budget id suggest
1) gears and an lsd(best bang for your buck besides n20, ir f/i
2)LT headers and exhaust
3)cai and UD pulleys
that oughta keep ya busy for a while
Old Nov 4, 2008 | 05:50 PM
Dipper2491's Avatar
Dipper2491
What is a stroker kit? and where can I find an affordable 1?
Old Nov 4, 2008 | 11:56 PM
jthorn9's Avatar
jthorn9
The Godfather
A stroker kit is a kit that uses longer and stronger push rods and pistons to allow for a longer "stroke" (the up and down length the piston travels).
www.supersixmotorsports.com sells reputable stroker kits, keep in mind, performing this kind of work is no wheres even remotely cheap. The entire engine needs to be disassembled, honed, bored (depending on the stroker size), cleaned, and then fully reassembled with the new kit, all in all, it's extremely costly for the power gains, however your block will be stronger than carbon steel (in a technical sense) and will essentially be brand new, aside from all the old parts that go back on.
Old Nov 5, 2008 | 10:09 AM
mustangman02232
you can pull a 4.2 v6 out of a 97-08 f150 and it will swap in
firecoyote
Sep 27, 2015 02:37 PM
warwickbass
Sep 20, 2015 04:51 PM
Roush05
Sep 10, 2015 12:23 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 11:50 AM
