injectors?
Old Nov 15, 2008 | 08:39 PM
gyea's Avatar
gyea
Default injectors?
so its been discovered that someone put somthing in my gas tank that started choking my car and has now totally clogged my injectors... a friend of mine has a set of 42lb injectors he will give me for free is it ok to put 42lb injectors in place of 19lb injectors =S
Old Nov 15, 2008 | 09:17 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Just managed to clog the injectors? Not the fuel lines rails etc?
Short answer: No its not ok....
Old Nov 15, 2008 | 09:29 PM
gyea's Avatar
gyea
yep just the injectors they barely spray and it isnt atomised the rest of the system appears to flow just fine whys the long answer as to why they cant be used out of curiousity i thought the system was computer controls and the ecu would compensate??
Old Nov 15, 2008 | 10:22 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Injectors require tune.
Old Nov 15, 2008 | 10:23 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I can get you a set of 19's all flow matched and everything, I'll GLADLY swap you for the 42lb injectors.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
