wiring fog lights
Old Nov 17, 2008 | 06:25 PM
winner99's Avatar
winner99
Default wiring fog lights
Can I just splice the headlights or parking lights and wire them in?? I have a GT to rape.
Old Nov 17, 2008 | 06:27 PM
Vovovovan's Avatar
Vovovovan
you can, but you'll need a stronger fuse. and if i were you i would run them to a switch.
Old Nov 17, 2008 | 06:38 PM
winner99's Avatar
winner99
ya but if Im taking it off a GT is it already one with the headlights?
Old Nov 17, 2008 | 08:45 PM
mustangman02232's Avatar
mustangman02232
your pulling the parts off of a GT or you think adding fog lights will make you beat a GT
Old Nov 17, 2008 | 08:54 PM
winner99's Avatar
winner99
Im pulling wires off of a GT but is it better to swap the intire light harness? Or can can I just wire part of it into mine? If i take the whole harness is there anything that has to be changed? I read somewhere that the fan fuse is double on the GT,
Old Nov 17, 2008 | 11:09 PM
Zach333's Avatar
Zach333
i thought wiring foglights in would as simple as putting it to the battery, through the firewall and to a switch mounted somewhere??
Old Nov 17, 2008 | 11:26 PM
haystackstang's Avatar
haystackstang
all mustangs have plugs for fogs if your pulling them of same generaton just plug in
Old Nov 18, 2008 | 12:49 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
No they dont. Only 94/95 came with the wiring for the fog lights from the factory. Anything after that you have to run the wiring to the center consel (if you want that OEM look), get a switch, run the lines to the lights themself, run a line to the battery, and run a fuse (or two).
Matthew
Old Nov 18, 2008 | 01:06 PM
haystackstang
Matthew
ok well i have a 96 and my friends 2000 has the wiring already there but we both ran wires to a switch etc im sorry i gave you semi correct info apparently only sn95s have the wiring
Old Nov 18, 2008 | 01:54 PM
3.8YOU's Avatar
3.8YOU
Thats what I did. Took only an hour and looks and works just fine.
