damnit
Old Nov 21, 2008 | 10:59 PM
moontang's Avatar
moontang
Default damnit
are there any pullies that have a tendancey of their bearings going out? i have a new whine that isnt my PS pump. a few weeks ago i had a really bad squeak taht started only when the car was cold then started happening more frequently i put belt dressing oon it that didnt help so i changed the belt that made the squeak go away but now i have a whineits nothing really terrible but it annoys me. i think it may be my AC so im probably goin to just get the AC delete from SSM i dont use it anyway ( i got the 270 AC [2 windows down at 70 miles an hour]) so anyway anyone know of a particular bearing that i should look at?
oh btw im thinking bearing cause it gets more noticible at higher RPM's
Old Nov 21, 2008 | 11:32 PM
Azrael's Avatar
Azrael
Nah, not a bearing, most likely. What tends to happen is that some belts vary in the exact formula of rubber they use. This can often cause a whining sound, that DOES get worse as RPMs go up. If you want to check, run the car, and hit the belt with a bit of lubricant on both sides of it. The sound should stop for a few seconds. If that is the case, you can either live with it, or get a new belt. This is the exact (and I mean in every way, even my initial thoughts were the same as yours) same thing that happened to me. That will teach me to buy the better belts.
my77stang
Feb 18, 2007 07:10 PM
Scotte28516
Oct 26, 2006 03:26 PM
