ok new problem
Old May 30, 2005 | 11:30 AM
Sickspackstang's Avatar
Sickspackstang
Default ok new problem
anyone have any tips on taking the brake caliper off of a 98 v6, i tried alot of different things and cant get it
Old May 30, 2005 | 10:55 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: ok new problem
Are you having trouble braking the bolt loose? Have you tried hooking 2 wrenches together or using a breaker bar. Also before you get started make sure you have a c clamp. You are going to need it to push the pistons in on the caliper. I have seen a lot of people try to put brakes on and can't do it because they didn't know to push the piston in. If you have any problems let me know, I'm ASE certified to work on brakes.
Old Jun 2, 2005 | 08:34 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: ZachW04Stang
Unless they're rear brakes in which case you will need a rachet and a rear caliper tool (a cube with differently spaced notches on each side) to twist that bugger back in.... Don't forget to loosen the Master Cylinder cap when you adjust the piston back in, otherwise all that displaced hydraulic fluid will have no where to go and just make it that much harder to push in.
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
