shifter help
Old Dec 11, 2008 | 11:29 PM
krazedcraka2000's Avatar
krazedcraka2000
Default shifter help
I am pretty new to the whole aftermarket upgrades, I want to put this auto shift **** on my 03 v6 stang, how hard will it be to take off the old an put in this one??? should i bring it to a shop or should i trust friends depending on how hard it will be.thanks !
http://www.coolblueperformance.com/i...PROD&ProdID=93
Old Dec 11, 2008 | 11:59 PM
my94pony's Avatar
my94pony
it should be an easy install i dont see any need to bring it to a shop .. search around online im sure there is a writeup on how to do it too
Old Dec 12, 2008 | 12:08 AM
mustangman02232's Avatar
mustangman02232
if you want a shifter do a B&M hammer shifter.
dont forget, you will have to re, wire your OD button switch
Old Dec 12, 2008 | 11:39 PM
Azrael's Avatar
Azrael
Well, in my opinion, T-Shifter from Hurst is #1. However, your install will be VERY easy. The ***** are screw on, screw off. Just give the leather boot a little tug to separate it from the bottom of the ****, then unscrew the ****, and screw on the new one (plus all the stuff mustangman02232 was talking about above me).
Old Dec 13, 2008 | 12:12 AM
03sixbanger's Avatar
03sixbanger
Ryan's Backup Mod
he is talking about an auto shifter
Old Dec 13, 2008 | 12:26 AM
Azrael's Avatar
Azrael
From the link, it appears to be.
Old Dec 13, 2008 | 12:54 AM
03sixbanger
Ryan's Backup Mod
i know but from your last post it sounded like you were talking about 5sp handles
Old Dec 13, 2008 | 12:49 PM
Azrael's Avatar
Azrael
I suppose I should have worded that differently. The **** will come off the same, it just needs more.....persuasion. Plus, you have to disconnect the wire for your overdrive switch. Then, just run the whole process in reverse for the new ****, and you're done (unless you screw one of those steps up). The whole thing should take all of 10 minutes, if you are working at a tedious pace, so as not to break anything. Otherwise, you could do it in 2-3 minutes, but, you may not have an O/D switch anymore (though that wouldn't make you the first, I'm sure).
Old Dec 13, 2008 | 06:25 PM
krazedcraka2000
so my auto shifter comes off by twisting it?? watching out for the o/d wires, will the new shifter have to be wired in??? Link all the way on top.
Old Dec 13, 2008 | 07:20 PM
jthorn9's Avatar
jthorn9
The Godfather
OK, here's how you remove the auto ****, very simple:
Start the car up and put the **** in neutral, or all the way down for maximum room to work, turn the car off, it will stay stuck in the position.
Get the appropriate allen wrench, there is a hole at 12 o' clock position on your shifter.
Put the allen wrench in the hole and lossen it till it comes all the way out.
Now give it a slight twist and pull, you'll have to pull fairly hard, the OD will come out with the shifter top, it just sits in there.
Get some a wire stripper and strip the two OD lines, and reattach them to the OD button (they'll probably come off when you take off the shifter, or if you get one from MGW it'll come with a new OD button).
Line everything back up, and push the new shifter on.
Rescrew in the allen screw.
Turn the car on, put it back in park, or drive.
