Help! Serious Knocking
Old Dec 21, 2008 | 12:36 AM
mpfink's Avatar
mpfink
Default Help! Serious Knocking
Hey All
Had a serious knock develop at about 55,000 miles.
The car is a 2000 with the 3.8L V6.
When the engine heats up it has a serious knock. Will knock under ANY load and continuously.
The cylinder closest to the firewall on the passenger side seems to be the issue. Pulled the plug and the plug was corroded/carbon filled and the wire was cooked ... running far too hot.
I changed the wires and plugs and it stopped the problem for a few hundred miles and is now back.
Has anyone had this problem? What might cause this? Injector gone bad?
Any help would be appreciated.
Thanks!
Old Dec 21, 2008 | 06:16 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Is it knocking, tapping or pinging? Knocking comes from the bottom end, pinging and tapping comes from the top end.
Old Dec 21, 2008 | 12:09 PM
mpfink's Avatar
mpfink
It's a serious pinging then...
Pre-detination by the sounds of it.
Old Dec 21, 2008 | 12:16 PM
RyansQuick6
Reverse Gear Member
OK, so you'r getting detonation, is anything done to the car at all or is it all stock?
Old Dec 21, 2008 | 03:34 PM
mpfink's Avatar
mpfink
Nothing's been done to the motor. Bone stock. So not sure why.
Old Dec 21, 2008 | 05:33 PM
cobra232's Avatar
cobra232
your car is a 2000 which had serious PCV issues. the poor oil baffles in the valve covers allowed the PCV to suck up too much oil into the intake which causes heavy spark knock.
you need to upgrade to either 98 valve covers or the late 01 and up covers. you can find the upgraded cover kit on ebay. just look for windstar valvecover.
next you need to change the spark plugs after you run seafoam through the PCV line to clean out the oil/carbon deposits in your intake and intake valves. these things will cure your problem
here ya go
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
Old Dec 21, 2008 | 06:23 PM
mpfink's Avatar
mpfink
Thanks for the advice.
I don't know very much about these motors unfortunately.
Hopefully will solve the problem and luckily is a pretty cheap fix.
Old Dec 23, 2008 | 12:31 AM
cobra232's Avatar
cobra232
they are great motors. the fix is pretty cheap. alot of guy's just delete the breather and PCV but it's not emissions legal in the US to do so and probably not in canada either
best to just get a set of 98 valvecovers from a junkyard wrecked car or the upgraded cover in the ebay link i provided. like i said run 1/3 can of seafoam through the PCV line into the intake and shut the engine off and let it sit for 10-15 min. go back and start the car back up. it will smoke like a diesel on a sub zero winter day for a few minutes. that's the oil/carbon deposits being burned off. it would be a good idea to do it a couple of times before you change the spark plugs for fresh autolite double platinum APP 764 plugs
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
flash_xx
Oct 16, 2015 07:23 AM
jessicarabbit
Sep 25, 2015 12:41 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Sep 3, 2015 07:14 PM
