blown head gasket?
In the winter i drive a 96 ford windstar.. and i think it is dieing..
It has been billowing white smoke from the exhaust. Ive been trying not to run it but within just the mile to and from campus (only done once since it started) i felt like a steam locomotive.
My windstar has 197k miles on it, did i blow the head gasket? and is it worth fixing?
White smoke means your burning coolant. So somehow coolant is making it's way into the combustion chamber and out the exhaust. So a head gasket would be the most likely cause.
I wouldn't bother replacing it, personally. If you can do the work yourself, it might be worth it, but at 200k it's bound to find something else to break. So unless you really like the car, I'd find something else.
wow have cars really come to the point where a blown head gasket is just cause to buy a whole new one?!
id fix the gasket and check to make sure its not burning oil or anything else and try to hang on to it for a while.
unless you got lots of money, in which case disregard that
Actually, yes. The car has almost 200k on it. A head gasket it self is probably like $50-100 depending on brand and where he gets it. Labor is the problem. I haven't worked on Windstars, but mini vans are FWD, meaning a transversely mounted engine. If it's the front head it won't be too bad to get to, but if it's the rear one it probably can't be done with the engine in the car. He's looking at some serious labor charges and downtime, where at that point it might be more cost effective to sell it and get something more reliable.
you can replace the rear head gasket in vehicle. but its a 96 windstar with 200k. most of the time a 3.8 with those miles and a bad head gasket will throw a rod soon after repair due to the coolant that entered the oil.
