how to tell if my stangs a 99-00 or 2001+
Subscribe
Jan 24, 2009 | 08:18 AM
I'm looking into getting an asp udp soon and I know there is a difference between the one for the 99-00 and 01+. When I bought the car I was told it was a 2001 however I checked my manual the other day and it said 2000. so I'm just curious if there is any way I can tell for sure. arn't there some interior differences? thanks
Jan 24, 2009 | 08:57 AM
Look inside your driver side door at the id tag, it will tell you when it was produced. Mine is a 95, but was made in Oct of 94 (so yes it was sold 95 year, but technically it's a 94 as it does have a 94 ECU, saw that when I pulled it out).
Jan 24, 2009 | 09:13 AM
vin # search
Jan 24, 2009 | 09:19 AM
99-early 2000 also had different spoilers than the 01+
Jan 24, 2009 | 09:37 AM
Quote: 99-early 2000 also had different spoilers than the 01+
Didn't they start the smoked headlights in 2001?
Jan 24, 2009 | 09:43 AM
I know but i think mine has like an aftermarket reproduction of the stock spoiler because it has this little sticker on the underside of it.
Jan 24, 2009 | 09:46 AM
01+ had black housing headlights (stock). Even if your car was made in 00, it was LATE 00 to be an 01 car. Midway through 2000 they switched to the internally bal motors.
Look at your pulley itself. There are two versions. The 99-00 has a bit of a weight on it. When looking at the inside of the crank pulley (where it bolts to the shaft), you'll notice a good thick edge, but it doesn't go all the way around the circle. That is the weight. It's matched to a weighted flywheel.
The newer cars are smooth the entire inside edge of the pulley, and use a zero bal flywheel as well.
Jan 24, 2009 | 10:01 AM
when did the engines change from internally balanced to externally or the other way around?
Jan 24, 2009 | 10:04 AM
mid 2000 I believe
Jan 24, 2009 | 10:06 AM
Thanks guys Ill check the door and pulley.
