Synchronizer Problems :(
Old Feb 19, 2009 | 06:43 PM
lil_sixer's Avatar
lil_sixer
Default Synchronizer Problems :(
I drive a 97 Camaro RS
My car wouldnt shift to gear but when i pump it,it does.So i changed the whole clutch spending a lot of money.And after that Its still doing the same thing,I tried leaking the Clutch oil and everything and it still the same,So i took it to the Shop and he said i need a whole new Synchronizer.Then i took it home. Now the real problem is there is no tension on the clutch,I can start the car when i press the clutch in neutral but i cant start it when i have it on any gear. Wat shud i do?I tried pumping it,still aint working!!Im tired of this crap,somebody pls help me out so that i can start it!!
Thanks
Old Feb 19, 2009 | 07:12 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
does it needa new synchronizer, which is what helps you shift between gears, or does it need a new slave cylinder, which actually controls the clutch from the pedal?
Old Feb 19, 2009 | 08:26 PM
lil_sixer's Avatar
lil_sixer
Well i replaced the slave cylinder man so i dont have any idea wat to do
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
