Need help with Winstar install
Old Mar 11, 2009 | 11:45 AM
crysalis_01's Avatar
crysalis_01
Banned!
Exclamation Need help with Winstar install
I'm at the final steps of installing my "new" Windstar intakes on. The heads, the lower, fuel rail, and upper is on. I'm now in the process of hooking up all the vacuum lines and electrical stuff. Here are my problems:
1) I'd like a little help with getting all the vacuum lines to the correct places.
2) How do I get the throttle harness to reach it's new position?
3) I've deleted my EGR, how bad will this affect things, until I can get it shut off?
4) And I've bypassed my PCV as well, any problems there?
Old Mar 11, 2009 | 12:50 PM
Archion's Avatar
Archion
Did you buy a kit, or did you piece it all together. All the ones I have seen have a modified throttle body and shaft.
Old Mar 11, 2009 | 01:40 PM
stangant's Avatar
stangant
1)On the lines really easy to do just match holes pretty much thats what i did. You will have to run 2 lines out of the top hole i did my IAC and the hose that is about the same size.
2)you will need a bracket
2.5)Is the stock hood being used?
3)EGR delete will lower gas mailage.
4)you should not have a problem.
Old Mar 11, 2009 | 03:24 PM
crysalis_01
Banned!
My throttle problem is that, from what I can see, the wiring won't reach. Is it affixed somewhere that i don't know or do I need to do some splicing/lengthening?
Old Mar 11, 2009 | 09:30 PM
Archion's Avatar
Archion
take a look at his cardomain page in his sig, you will see the bracket he is talking about.
Old Mar 12, 2009 | 11:33 AM
crysalis_01
Banned!
Ok. Just to clarify. I'm not talking about the throttle cables. I'm talking about the wiring that connects to the TPS.
Old Mar 12, 2009 | 12:30 PM
amrcnidyot's Avatar
amrcnidyot
you can just extend it. get some wire that is the same gauge then cut the old wires in half and solder the new pieces of wire in.
Old Mar 12, 2009 | 12:44 PM
crysalis_01
Banned!
Thanks. This actually the set up i baught from you over a year ago. I've only just now gotten to the install.
Old Mar 13, 2009 | 07:29 PM
crysalis_01
Banned!
OK. Everything is on mechanically. But now I have a car that runs like a total POS. It won't idle, it's burning too much fuel(black smoke), and at has absolutely no acceleration. It may be making a hell of a lot more power but it feels like I'm driving a busted as VW bug.
I'm still so damn confused as to where the vacuum lines need to go. I've got the one that comes off the fuel rail, the red and green ones near where the EGR is, the brake booster, and the one from the IAC. Is that right?
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
