Installing JVC KD-AVX11
http://www.sonicelectronix.com/item_...6-MCA2004.html
or
http://www.woofersetc.com/index.cfm?...roduct_ID=6557
Ditch the subs and try these:
http://www.woofersetc.com/index.cfm?...roduct_ID=2129
Powered By:
http://www.woofersetc.com/index.cfm?...roduct_ID=6553
In this box:
http://cgi.ebay.com/ebaymotors/1994-...sQ5fEnclosures
You can try other brands, but I'd have to say, go 12" I went 10, and I'm semi regretting now going 12, they just don't, I don't know, but they just don't seem right some times. Also, same sub box in my car, quality is great. Diamond audio makes great products however I have heard some bad things about warranty issues, but if it's wired right you shouldn't have any problems. If this scares you look at Hifonics amps for the subs.
i cant fit two 12's in my trunk because of the convertible, so I don't think that box will fit. And the sub was a 15", I deffinatly can't fit two 15's lol. How about a custom box that will work with two 10"s any idea? thanks for the help.
Oh, wasn't paying attention, I meant to link over the 12" sub.
Converts are more tricky, I haven't found any custom boxes for convertables, you'll either have to make your own, or just use a universal box.
Well I'm pretty sure I can fit one 12, would you reccomend the same sub/amp if it was just one 12. And I'm no sound critic or anything so if you know of someone thats still decent but a little cheaper that would be great. thanks for the help man.
Well those two sites are about the cheapest, however when it comes to subs/amps I wouldn't go cheap, going cheap means poorer sound quality, more distortion, and the possibility of blowing a sub. Yes you can fit one 12" sub, let me look up a new amp/sub.
Sub:
http://www.woofersetc.com/index.cfm?...roduct_ID=2128
Amp:
http://www.woofersetc.com/index.cfm?...roduct_ID=7502
or
http://www.woofersetc.com/index.cfm?...roduct_ID=6556
There are other good brands for amps, however these two are the more economical of the best, Hifonics used the be on top like 10 years ago before other companies began copying their design.
There are also other good brands in subs, however pay attention to the sensitivity rating, the higher the rating, the better the sound quality. Name brands such as JL, Alpine, Kicker, etc. are OK mid range brands, but brands like Memphis, Elemental Designs, Rainbow, Sound Splinter, and other not so common brands are about the best you'll get.
Amp:
or
Sep 10, 2015 08:39 PM
