Check engine light is on...
Old Mar 29, 2009 | 09:40 AM
Xemeth's Avatar
Xemeth
Originally Posted by Zach333
ROFL rawful rawful
Not too sure what's funny about that. The first digit being "C" means it's a chassis code, and the "xxx" are stuck in a variables cause I forgot what the exact OBDII codes for the wheel speed sensors are. I didn't want to throw out numbers and possibly try and lead him down the wrong path. Unlike most of this section, I actually like to make sure I know what I'm talking about before I start spewing random bull**** out of my ***.
Old Mar 29, 2009 | 10:12 AM
moontang's Avatar
moontang
coxxx it sounds like ***** thats what hes laughing at
and +1 to speed sensor or you pulled the wire or something little like that
Old Mar 29, 2009 | 10:19 AM
tat2dmeatman's Avatar
tat2dmeatman
Tat2d Member
Well, it's getting put up on jack stands today. We'll see what happens..Thanks for the advice guys.
Old Mar 29, 2009 | 11:27 AM
Zach333's Avatar
Zach333
yeah i understood what you said Xemeth no need to throw a temper tantrum and rant about your greatness... i was just playin around
Moontang understood
Old Mar 29, 2009 | 05:54 PM
tat2dmeatman
Tat2d Member
Default A learning experience for me...
Wow. So today has been an experience. I jacked up the front of the car and pulled the front wheels. Checked the sensors on both sides. Passenger side looks suspiciously like it may have been changed once before. Has anyone else had to change a wheel sensor? Where do you disconnect them? Cleaned both and re-installed. ABS light still on. Started to do the rear brakes (since I already had my tools out) when I ran into a problem... Cleaned and re-installed the sensor on the drivers side, then tried to compress the caliper (as shown in the Haynes manual) and it would not compress. Anyone else run into this? I actually snapped my 4" C clamp in half trying to compress the caliper. The only up side I can find so far is that it gave me a chance to scrub the dirt out of the inside of my wheels. Seriously though, did I miss something somewhere? I didn't have the parking brake set, and I had the cap off the brake fluid reservoir. All suggestions appreciated.
Old Mar 29, 2009 | 08:22 PM
Xemeth's Avatar
Xemeth
The rear brakes need a special tool. They need to be compressed and turned in (clockwise) to compress. You can probably rent the tool at AutoZone or something.
Old Mar 29, 2009 | 08:52 PM
tat2dmeatman
Tat2d Member
Well that explains it. Why in the hell would Ford build something like that? Anybody have any idea what that tool is called?
Old Mar 30, 2009 | 11:22 AM
Xemeth's Avatar
Xemeth
Just go to AutoZone and ask for the brake caliper piston tool. They should know what you're talking about.
And it's not just Ford. A lot of car companies use this style of piston on their car's rear brakes. Beats the **** out of my why, but they do.
Old Mar 30, 2009 | 12:53 PM
99V6Auto's Avatar
99V6Auto
Good luck, its pretty easy to do
Old Mar 30, 2009 | 02:34 PM
tat2dmeatman
Tat2d Member
Thanks guys. Should be done this evening.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
