Amp Ground?
Alright, I've got everything ready to be hooked up in my trunk, Amp, Subs, Wires all in place, but I was just wondering where would be a good place to hook up the amp ground wire?
Thanks guys.
...And I know there is a section for this, but they are not hittin' a lick in the audio section...
Thanks guys.
You don't want it to be too long, it can act as an antenna for noise. I try to keep mine under 18" Make sure it is at least the same gauge as the supply wire coming back from your battery/load center. There are a couple of factory grounds in the trunk that are good to use. Just make sure you have a clean unrestricted connection
all kinds of places to ground out your amp....where ever you choose make sure its a clean surface, ie. use an emery cloth and clean it down to some nice shiney metal so that you knoe it is going to make a nice connection.
You want as little resistance to ground as possible, just like a free flowing exhaust...
here is a nice chart for you...
http://www.the12volt.com/info/recwirsz.asp
