Few problems with my sixer
Old Mar 30, 2009 | 08:46 PM
Jigsaw07's Avatar
Jigsaw07
Default Few problems with my sixer
Well yesterday I noticed that at idle, my car will not go under 1k rpms and every I'd say about 15 or 20 seconds, the rpms climb to about 1.6k by themselves. Another thing is when im driving over 2k rpms, and I go into neutral or hit the clutch, the rpms stay at 2k rpms for about 30 sec. My car has an exhaust leak, but I'm wondering if that's the reason for all of this? Or maybe I need new plugs and wires? Any help would be great. Thanks guys.
Old Mar 30, 2009 | 09:04 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Sounds like a sticky throddle cable...
Matthew
Old Mar 30, 2009 | 09:19 PM
Jigsaw07's Avatar
Jigsaw07
So how would I fix this? Getting a new cable?
Old Mar 30, 2009 | 10:23 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
MIne has done it a few times recently as well. I just blip the throttle and it drops right down.
Old Mar 31, 2009 | 03:37 PM
l_shizzle_l's Avatar
l_shizzle_l
Whenever my idle hangs I drop in into a higher gear and slowly let out the clutch. Could also be a dirty IAC.
Old Mar 31, 2009 | 07:07 PM
Jigsaw07's Avatar
Jigsaw07
What is a IAC? Another thing I noticed today was when I have the air on, and rev the car to about 1300 rpms, it starts shaking and acting like it wants to stall. Its only from about 1200-1400 rpms. If I go over that then it's fine.
Old Mar 31, 2009 | 09:38 PM
ayrton02's Avatar
ayrton02
The shaking and such sounds like a misfire. However, the other symptoms sound like the IAC (idle air control) valve or possibly the MAF (mass airflow) sensor. The IAC valve is located on the side of the throttle body closest to the firewall. Take it off and spray some carb/choke cleaner in there. The MAF sensor can be cleaned using MAF sensor cleaner - available at an auto parts store. Be very careful... you don't want to break the filaments in the MAF sensor. I'd also recommend a changing the plugs and wires if you haven't done that. Autolite coppers or stock Motorcraft plugs are great. MSD makes great plug wires. Check the air filter, see if it's dirty and replace if needed (get a K&N filter if you're gonna replace it).
Using Seafoam is also a good idea. You only need two cans.... here's how to use it:
http://www.ls1tech.com/forums/genera...-your-car.html
Those directions were written by someone with a LS1, but the procedure is basically the same. I'd suck it up through the PCV valve instead of the brake booster though because with the intake design, it will disperse more evenly throughout the ports. Be sure to change your oil like they say too. Ignore the part about the Deep Creep stuff.
Other than that, idk man. You might as well replace the fuel filter and call it full tune up (excluding transmission fluid and filter... lol). Even though some of these remedies may not be the solution, it's a good idea to get everything fresh and up to date. And I'm pretty sure that if you do all of this, it will fix the problem and your car will run much better.
Old Apr 1, 2009 | 01:29 AM
SVTeeshirt's Avatar
SVTeeshirt
i'd suggest an entire tuneup, never hurts, if you are hurtiing for money i'd bet on the iac or TPS(if you guys have these?) lol throttle position sensor, if you can spare a little on your car i'd suggest.. new fuel filter/ spark plugs wires/ clean the IAC/ new air filter, never hurts.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
