Help
Old Jun 19, 2005 | 12:23 AM
BW_Mustang's Avatar
BW_Mustang
Default Help
I was wondering if it is better to turn overdrive on or off. I have a 95 Auto and i wasnt sure what overdrive does for me if anything. So let me know if its better to have it on or off or what situations to have it on or off....thanks
Old Jun 19, 2005 | 01:00 AM
CraZy6's Avatar
CraZy6
Default RE: Help
just leave the overdrive on. Its better for gas, but you can turn it off if you wan to stay at higher Rpms. You will burn out your tranny if you keep the overdrive off. Due to the heat that will buid up on the tranny.
Old Jun 19, 2005 | 05:17 PM
BW_Mustang's Avatar
BW_Mustang
Default RE: Help
Ok thank you i have driven with overdrive off ever since i got the car i will be sure to turn it on when i get back in my car...
Old Jun 19, 2005 | 07:04 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
Default RE: Help
overdrive will allow you to reach only 115mph if it is on. you can reach 120mph with it off. it is a 3speed without o/d, o/d is the "4th" gear.
Old Jun 19, 2005 | 09:23 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: Help
ORIGINAL: AtlanticBlue99
Its the other way around in my car. My 3rd gear is still only at 4800 rpm then also.
Old Jun 20, 2005 | 01:10 AM
BW_Mustang's Avatar
BW_Mustang
Default RE: Help
So if i have OD off i can do 120 and if its on i can only do 115. That doesnt make sense b.c OD acts as your 4th gear wouldnt that allow you to reach a higher speed?
Old Jun 21, 2005 | 01:43 AM
ZachW04Stang
Default RE: Help
The car shifts into 4th at 105mph when over drive is one and stops at 115mph. When overdrive is off it goes up to 120 in 3rd and stops at 4800 rpm
Old Jun 21, 2005 | 06:33 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Help
ORIGINAL: BW_Mustang
No because you reach the speed limiter with OD. 3rd doesn't push that one, rather it pushes the rev limiter. Same thing in a 5 speed manual tranny. I can do 120 at close to redline in 4th but in 5th, my speed is limited to 115 at 3500rpm.
