00-01 engine diff
Old Apr 20, 2009 | 05:11 PM
stangant's Avatar
stangant
Default 00-01 engine diff
I am going to be starting a build soon. I found the 01 block that will hold the boost pressures but is only the block. I have also found a blown 2000 block with everything but the heads(which i do not need). What are the differences and will i be able to directly bolt the 00 parts to the 01? Any other info that I can do will be great.
Old Apr 20, 2009 | 09:13 PM
stangant's Avatar
stangant
anyone
Old Apr 20, 2009 | 11:47 PM
l_shizzle_l's Avatar
l_shizzle_l
are you going to be using the stock rotating assembly? everything else should swap right over with a couple of sensor changes. the main difference is the engine balance and the oil pan clearance.
Old Apr 21, 2009 | 07:32 AM
stangant's Avatar
stangant
i will be using a super coupe crank.
Shouldn't the oil pan from a 00 swap to the 01 then?
Old Apr 21, 2009 | 11:49 AM
LilRoush's Avatar
LilRoush
'01 oil pan is deeper - so the 4.2/4.3L guys us that pan to clear the larger crank.
3.8L Blocks are the same for those years.
Old Apr 21, 2009 | 12:42 PM
l_shizzle_l
It's not deeper but rather a bad design. The back of the 99-00 pan is molded in and contacts the last main cap on the 01+ blocks, thus leaving you a 1/4" - 1/2" gap between the block and the oil pan which a gasket will not seal lol. I've bought 2 oil pans for my 4.3 i'm building and they were both 99 pans and did not clear
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
67LimeCoupe
Sep 30, 2015 04:46 PM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
