Auto Gauges !!
Old Apr 29, 2009 | 02:15 AM
xToPPxDoGGx's Avatar
xToPPxDoGGx
Default Auto Gauges !!
what are some good gauges to get meaning like the volt, or oil , or temp??
im not gonna put any boost ones , but what are the ones i should get to monitor the motor or any thing eles ??
Old Apr 29, 2009 | 03:18 AM
cuban tech's Avatar
cuban tech
autometer has some good one's i recommend oil pressure, water temp, trans temp,volt, and oil temp, vacuum. those would be good.
Old Apr 29, 2009 | 09:39 AM
mudvayne1's Avatar
mudvayne1
Whats wrong with the ones in your instrument cluster? Autometer is the best.
Old Apr 29, 2009 | 05:14 PM
cuban tech's Avatar
cuban tech
the gauges in the cluster are not accurate at all.
Old Apr 29, 2009 | 10:31 PM
xToPPxDoGGx
any idea on which ones are the most important ??
Old Apr 30, 2009 | 01:07 AM
jthorn9's Avatar
jthorn9
The Godfather
Why waste your money on gauges you already have in your cluster. If the gauges in the cluster are off, then something is wrong in either the cluster or the sending unit for the gauges.
Old Apr 30, 2009 | 03:41 AM
cuban tech's Avatar
cuban tech
the stock gauges like oil pressure tell you nothing. none of the stock gauges are accurate. the important one: oil pressure, coolant temp
Old Apr 30, 2009 | 12:39 PM
jthorn9's Avatar
jthorn9
The Godfather
They should be accurate to a certain degree, if they're off, then you have a problem with the sending unit, as I said earlier, also, when in the hell would your oil pressure fall or raise higher than normal on a stock or even mildly moded car? My coolant temp gauge is 14 years old and still seems to function just fine, and believe me, it works properly.
Old Apr 30, 2009 | 01:04 PM
bgnn32's Avatar
bgnn32
jthorn, it depends on what you are doing with the car, for normal driving the stock gauges are more than enough, if you are turning the thing into a road course racer you want highly accurate gauges.
Most importiant are Tach, Oil Pressure, Water Temp, Oil Temp, and Voltage.
Old Apr 30, 2009 | 05:47 PM
jthorn9's Avatar
jthorn9
The Godfather
OK, is your car a road racer, hell I have an S/C on the way and the only extra gauges I'm using is the boost gauge and a/f ratio gauge, stockers will do just fine. Yes, I agree, you do need highly accurate gauges when running that kind of car, but last time I checked, only a few people on this site have that kind of car, and generally, they also include a shift light (manuals), amongst 20 thousand other things as well.
