3.8 Compression
Old May 1, 2009 | 07:11 PM
jarod17's Avatar
jarod17
Question 3.8 Compression
First off, if this has been posted already I apologize. I looked for an hour without finding the answer.
I just got a '94 mustang with the 3.8 and am going to do a compression check once the car is delivered. I know how to perform the check but do not know how much pressure is supposed to be in each cylinder. I am also looking at a 3.8 out of a t-bird SC. If the pressure is different in this engine than in the mustang 3.8 what pressure should this be.
Thanks in advance.
Old May 2, 2009 | 12:35 AM
crysalis_01's Avatar
crysalis_01
Banned!
Compare the highest reading from each cylinder to the others. The indicated pressures are within spec as long as the lowest reading is within 75% of the highest reading. For example if the highest is 150 psi, then 75% below would mean a minimum 113 psi. That make any sense to ya?
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
mrappe
Sep 26, 2015 10:16 AM
col2560
Sep 25, 2015 08:59 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
