Can someone help me with my ac problem
Old Jun 18, 2009 | 09:06 PM
wizzap's Avatar
wizzap
Default Can someone help me with my ac problem
95 mustang vac problem Ive been looking for a vac leak cause my ac will only blow out defrost
I checked lines under dash No vac long story short I found the line was broke at the vaccum block I fixxed it and have Vac all the way up to a splitter with a pig tail in it it has the numbers E4ZF-9C915-AA and E0995b there is Vac going in to it but none comeing out and the air still only blows out the defrost
Found out that part is a vapor canister purge siloniod does that even have anything to do with the AC
did pull the glove box there is a red yellow and blue line that goes into a plug that has a white line that goes into a thing thats on the firewall that white line has no vaccum
Old Jun 19, 2009 | 12:00 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Check the blend door and the blend door actuator to see if they are functioning or damaged. A blend door actuator can go out pretty easily, although it's not too common.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
