Limited Slip Question
so money's a little tight and I was wandering if I could add just an FFRP limited slip to the rear end, replacing the open dif. I don't have the extra money for gears and a tuner. I live in the northwest and really need more traction for the winter (I'd like to add a limited slip to snow tires and weight in the trunk).
mainly I was also wandering if I could replace the open dif with a limited slip myself (without having to worry about readjusting the clearances and backlash on the gears). or would I need a shop to do it for me even though I wouldn't be replacing the gears?
http://www.differentials.com/install.html
The answer is no, it's a bit more complicated than you think and I doubt you have the tools, but anyways here's a guide.
aright thanks for your guys' help. I'll have to look into it a little more. i might see what kind of money I can come up with and do the whole rear end at once since I'll most likely do gears at some point.
JoshyGT
Sep 19, 2017 08:52 PM
treesloth
Sep 28, 2015 07:03 AM
