Am I missing anything?
Old Jul 6, 2009 | 10:45 AM
99'PEGASV6's Avatar
99'PEGASV6
Default Am I missing anything?
last month I changed out spark plugs, wires, and had an oil change. Car has 140k miles on it. Any other little matinence thing i should check out/do? any little suggestion for replacement would be great. Thx
Old Jul 6, 2009 | 12:20 PM
bgnn32's Avatar
bgnn32
Flush the radiator, air filter, fuel filter, how are the brakes?
Old Jul 6, 2009 | 01:13 PM
ayrton02's Avatar
ayrton02
Transmission fluid, rear end oil, PCV valve
Old Jul 6, 2009 | 02:15 PM
99'PEGASV6's Avatar
99'PEGASV6
time to get to work haha..
I had a bbk CAI installed in november, should it be time to clean it already?
nd these are all doable by myself yeh?
Old Jul 6, 2009 | 02:58 PM
bgnn32's Avatar
bgnn32
Depends on the conditions you drive in, I live on a dirt road and am constantly replacing/washing my air filters, about every 3 months.
Everything mentioned is doable by yourself.
Old Jul 6, 2009 | 04:51 PM
Shaunmac9128's Avatar
Shaunmac9128
+1 to all that stuff, and it is all doable at home with a little knowhow.
Old Jul 6, 2009 | 06:46 PM
Fink's Avatar
Fink
Isnt the transmission fluid one of those things that you should either never change or change at regular intervals?
Old Jul 6, 2009 | 08:09 PM
ayrton02's Avatar
ayrton02
That's flushing it. A simple drain and refill is recommended every 30,000 miles.
Old Jul 6, 2009 | 08:26 PM
SilverOnyx1's Avatar
SilverOnyx1
You might want to look at your brake fluid, check to make sure it's not brown or worse. Also you may want to change the fuel filter.
Old Jul 6, 2009 | 08:40 PM
Shaunmac9128
Yeah when I did my brakes the fluid was complete garbage, deffinatly check that out, its easy to flush out.
