Replacing struts?
Old Jul 19, 2009 | 11:33 AM
baddog671's Avatar
baddog671
Default Replacing struts?
Since my 98 doesnt have the front strut/coil spring unit, they are separate, it should be pretty easy to swap them out, correct? I have access to a drive on car lift, so couldn't I lift it and undo the bottom 2 bolts, drop it and undo the tops which should let them fall out, lift it and bolt up new ones, and then drop it and tighten tops?
Old Jul 19, 2009 | 12:10 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Go look in the stickies on how to do a drop
Old Jul 19, 2009 | 02:11 PM
Shaunmac9128's Avatar
Shaunmac9128
Yeah its really easy and completely doable with hand tools and no lift, just time consuming. Follow ryan's sticky.
Old Jul 19, 2009 | 02:59 PM
baddog671's Avatar
baddog671
WHy should I have to remove the wheels, brakes, and all that other crap? Why cant I simply undo the bolts and slid it out??
Old Jul 19, 2009 | 08:16 PM
Shaunmac9128
You don't have to undo the brakes and taking the wheels off isn't that big a deal man. Try it your way and let me know how it works.
Old Jul 20, 2009 | 07:33 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
I took mine off, while the car was on the ground, without touching the breaks at all, I did need to take the wheel off though.
Matthew
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
GentleBen
Sep 11, 2015 05:34 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
