e fan problem
Old Aug 19, 2009 | 10:11 PM
Sgt. G's Avatar
Sgt. G
Default e fan problem
my gf has a 2004 3.8l v6 with a wierd problem. the electric fan isnt coming on. the temp meter runs to half way point and a little past an it dosent come on. i already checked fuses and replaced a circuit breaker that is supposed to be for the fan and still nothing. the fan however does work because i tried to connect it directly to a battery and it worked....any ideas? is there some sort of thermostat switch or something?
Old Aug 19, 2009 | 10:28 PM
killbillet's Avatar
killbillet
there should be a relay
Old Aug 19, 2009 | 10:36 PM
brent4's Avatar
brent4
Does/has the car overheated?
Old Aug 19, 2009 | 10:51 PM
Sgt. G's Avatar
Sgt. G
the car hasnt overheated becauase we turn it off once we c it get passed the half way mark on the temp gauge, and i looked on the manual and it is a circuit breaker fuse that it codes for for the fan. if it was one of the major realys wouldnt it also effect other functions as well?
Old Aug 19, 2009 | 10:53 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
The temp sender may have failed
Old Aug 23, 2009 | 03:31 PM
NeoTokyo's Avatar
NeoTokyo
If I remember correctly, turn the AC to MAX and that should turn the fan on. If it doesnt work, take that with a grain of salt because it never worked on either of mine (95, 96) :P
Being a 2004 it has two sending units if I remember correctly (Theres that phrase again :P ) one for the guage cluster and one for the ECU.
My 2000 3.8L that I bought has two sending units where my 95 and 96 only have 1.
Old Aug 23, 2009 | 07:48 PM
brent4's Avatar
brent4
I had the temp sending unit on the driver side head go out/i broke it and the fan would come on the second I cranked the car and stayed on until I turned the car off.
jma2
Jul 10, 2023 01:00 AM
aznpersuasion
Jul 11, 2018 06:40 PM
Nov 10, 2015 11:39 AM
jaiidutch
Sep 14, 2015 10:29 AM
Sep 3, 2015 07:14 PM
