How farfetched would it be....
Old Sep 11, 2009 | 12:09 PM
FoRdBoY357's Avatar
FoRdBoY357
Default How farfetched would it be....
To swap in a 1990 Thunderbird SC motor in my 2000? I love my car but the miles are getting up there. If it's plausible and doable, I'll do it. I've got 2 SC motors. If it's way too much trouble, I'm going to do a 4.2 with a Windstar intake.
Old Sep 11, 2009 | 12:23 PM
jthorn9's Avatar
jthorn9
The Godfather
It's completely doable, but maybe a little illegal because of emissions standards in some states, but if you live in a state like I do, Louisiana, that could give a rats *** less, then you're fine. But keep in mind, you need more than just the motor, you need the complete wiring harness, ecu, cooling system, and a few other things to do the job. In other words, you need a donor t-bird.
Old Sep 11, 2009 | 04:32 PM
LilRoush's Avatar
LilRoush
Not something I'd waste time with. Use the bottom end, split port heads, good upper/lower and slap a blower on it.
Old Sep 12, 2009 | 07:50 AM
FoRdBoY357's Avatar
FoRdBoY357
We don't do emissions in my county in NC and I do have everything. Isn't it a different fuel system though?
Old Sep 12, 2009 | 12:01 PM
robinson209's Avatar
robinson209
Originally Posted by FoRdBoY357
...I've got 2 SC motors. If it's way too much trouble, I'm going to do a 4.2 with a Windstar intake.
Get the 4.2 with the Windstar intake. Sell one of the SC motors if you need the money to buy the 4.2.
Old Sep 12, 2009 | 02:51 PM
FoRdBoY357's Avatar
FoRdBoY357
I don't like selling engines. Haha. I want the torque of the supercharged engine more than anything. I'd rather rebuild an engine I already have than build an engine I'll have to buy. Who knows? If I happen upon a good low-mileage 4.2, I'll jump on it. Otherwise, I'm still wanting to do the SC swap.
And couldn't I just use the 3.8 wiring harness? They're the same motors. And all that's going to the supercharger are vacuum lines. I just have to know if it is the same fuel system. The splitport uses a return-style line, does it not?
Old Sep 12, 2009 | 03:30 PM
brent4's Avatar
brent4
Do like lilroush said and use the bottom end of the supercoupe engine get some split port heads and throw the eaton m112.
Old Sep 12, 2009 | 05:34 PM
mustangman02232's Avatar
mustangman02232
your best and cheapest bet would be to get a low milage 4.2 out of a wrecked f/E-150 and swap it in
Old Sep 12, 2009 | 06:33 PM
FoRdBoY357's Avatar
FoRdBoY357
I've seen that, and I was intrigued at first. But then I thought: The M112 adds A LOT of weight to the front end and that weight is up high from pictures I've seen. The whole reason I love my car is because it has better balance and lighter weight than a GT and I want to keep that weight as far down as possible.
New question. What power can I expect from a cammed, tuned, and Windstar swap and longtubes on a 4.2
Also, if I get one that needs a rebuild, I'm gonna go high-compression and metal headgaskets.
So, with a 10:1 4.2 w/ cam, headers, windstar intake, and tune, what can I expect? 250-270?
Old Sep 13, 2009 | 07:14 PM
LilRoush's Avatar
LilRoush
Not much weight added with the M112 set up. And weight trade off for power gain is well worth it. I wouldn't run that set up on an open track car if it didn't have good results.
To answer your questions, the 99-04 cars use a returnless fuel system, so you'd need to compensate for that if you do the swap. You'll also want to swap over a lot of the electronics if you can.
Well built N/A 4.2L cars can put down upper 200's for hp and tq. I think mine was like 247/256 or something @ the wheels with a blower cam and low comp set up. It's been so long I don't remember.
