used engine question
Old Sep 12, 2009 | 06:24 PM
ketchumjesse's Avatar
ketchumjesse
Cool used engine question
so, i have a 99 3.8l my engine needs replacing and i found one on ebay. the one i found says it will fit a 01-04. it says it is a vin4. is there any reason why this engine would not work with my stang? thanks
Old Sep 14, 2009 | 12:26 AM
ketchumjesse
anyone. No one knows? im thinking that it should, but am wondering if anything may be different on the 01-04s. mine is a 99
http://cgi.ebay.com/ebaymotors/01-02...Q5fAccessories
Old Sep 14, 2009 | 01:36 AM
Fink's Avatar
Fink
Exact same engine as yours besides the IMRC's in the lower intake. Oh and it is internally balanced instead of externally.
Old Sep 14, 2009 | 08:25 AM
ketchumjesse
ok, thanks for the info. i am really needing to get an engine SOON! And i really dont make a wrong purchase. what exactly does that mean the IMRC's in the lower intake. Can i just swap my lower intake to make it work? I would like everything in the swap to go smoothly.
next question - so my engine is internally balenced... not really to sure about what that means either. will this work?
If anyone knows, what will i have to swap to my new used motor
I am a fairly new member of the v6 community here on this site, and i really appretiate any info that is given to me.
Old Sep 14, 2009 | 09:31 AM
ketchumjesse
sry, the 99-00 is externally balenced and the 01-04 is internally. correct? Are these interchangable motors in our 99-04 or not?
Old Sep 14, 2009 | 01:35 PM
Fink's Avatar
Fink
Yes you can put that engine into your car. You will not need to swap anything. Itll drop right in. You can swap the lower intake from your current engine to the other one if you want.
Old Sep 14, 2009 | 10:24 PM
LilRoush's Avatar
LilRoush
Make sure the new motor has the flywheel on it, and that when you swap, you keep the RIGHT flywheel on there.
I pulled a swap in my car one time, and for the life of my couldn't figure out what we had done wrong. Turns out when we had the whole mess apart, we accidently put the wrong flywheel on. Motor had a nasty vibration to it when I fired it up.
Old Sep 15, 2009 | 08:09 AM
ketchumjesse
ok, basically it should be a direct swap, eh?
So, its fine that the new engine is internally balenced and mine is externally? Just as long as i dont put my flywheel on there...
I am not sure if the if the 01-04 engine i am looking at comes with a flywheel.
Would it be worth buying an alluminum flywheel?
Should i replace the lower intake? I mean i have one from my 99 engine. Any advantages of either?
I am mainly worried about all of the connections being the same and computer working properly with the newer engine.
Old Sep 16, 2009 | 12:09 PM
ketchumjesse
anyone?... i just wana make sure. thanks
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
