Engine Problems
Old Sep 22, 2009 | 04:40 PM
MCxQubed's Avatar
MCxQubed
Default Engine Problems
this morning i drove to school everything was perfectly fine, i get out of school to go home and leave after about 15 minutes the engine starts running rough, when i come to a stop it stalled, also i was going about 50 and it stalled randomly. After i got home i went out and tried to see what it was and i turned the car on let it idle it would dip down to about 700-800 rmp then go upto about 1120 rpm and do this repeatedly, i thought it was going to stall but it didnt after about a minute or two of that i just turned it off. Anyone know anything i found this link to a page where the guy had similar problems, and people suggested a new oil filter and clean the mass air flow sensor, i just wanted to see what u guys thought.
I have a cold air intake if that helps, it from am. Maybe something with that...
Thanks
Old Sep 22, 2009 | 04:59 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
If you haven;t had the intake on for very long or recently cleaned and re-oiled it, then some of that oil most likely deposited on the MAF. You should be able to pop it off anf take a look in there and if it's nasty, just use some brake cleaner on it, and re-install it.
Old Sep 22, 2009 | 05:04 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Maybe a problem with the fuel filter. Lack of fuel can cause problems with the engine too.
Matthew
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
