Stereo installation
Old Sep 27, 2009 | 12:36 PM
thetopbeast's Avatar
thetopbeast
Default Stereo installation
I got a roadmasterusa vrcd400sdu used, and i bought a wireharness from walmart. The power harness fits but not the audio. My car has amp in the dash so i took it out and cut the speaker wire and tried to hook them up to the stereo. Music does not come out of the speakers it only makes this buzzing sound when i turn the volume all the way.
here are some pics:
THis is the stereo
http://i208.photobucket.com/albums/b...m101/wire2.jpg
THis is the wire harness from walmart
http://i208.photobucket.com/albums/b...om101/wire.jpg
speaker wire that connects to the factory amp
http://i208.photobucket.com/albums/b...m101/wire3.jpg
I cut the wire cause the harness was the wrong one
http://i208.photobucket.com/albums/b...m101/wire4.jpg
Test with a speaker
http://i208.photobucket.com/albums/b...m101/wire5.jpg
I also tried getting a speaker and try each of the stereo speaker wire and there is no sound except for the buzzing sound.Im really stuck here. i dont know what to do. Could it be the stereo outlets? but it turns on and off. i need help
Old Sep 27, 2009 | 03:04 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
You have to bypass the amps, or run an SNI-15 adapter to tap RCA's into the amp inputs. It's better to let a stereo shop do it because it's very easy to fry everything if you don't get it right.
Old Sep 27, 2009 | 04:55 PM
thetopbeast
ok i take it to the shop but since i kinda cut the wires, they can fix that right?
how about the test i did with single speaker? why did that work?
Old Sep 27, 2009 | 11:01 PM
RyansQuick6
Reverse Gear Member
They can fix the ires and they won;t have to test the speakers, it's easy when you've done it a few times, but the first time is a pain.
Old Sep 28, 2009 | 01:30 AM
0949er's Avatar
0949er
another easy way to wire up a new head unit (at least this is easier to me) is just run a whole new set of speaker wires.
Old Sep 28, 2009 | 01:42 PM
audiofrek19's Avatar
audiofrek19
one of those plugs is a amp integrator harness its the one in i think your third pict on the left side. i think its a a wire harness thats going to your amp and they sell a harness that plugs into that and you just tap those wires into your speaker wires and done. you dont have to bypass the amp in that
Old Sep 28, 2009 | 04:28 PM
thetopbeast
im taking it to the audio shop on Wednesday. He charges me $120 for installing stereo and bypass, is that a fair price?. He told me to buy the bypass harness but i all ready cut the speaker wires that go into the amp.
I still don't know why do you have to do a bypass. Does the speaker sound the same when it bypass the amp? Do you have to take the amp out, or the car still needs it?
Old Sep 28, 2009 | 05:23 PM
0949er's Avatar
0949er
the amps are there because basically the stock receiver does not make enough power. (in lamens terms)
when you buy a new head unit, the new unit usually has enough watts output to not need to use the stock amps at all.
mtgldr
Feb 3, 2024 09:00 PM
Ford_Dude
Sep 15, 2015 03:25 PM
Sep 10, 2015 08:39 PM
TimeLord101
Sep 4, 2015 09:27 AM
