diablo predator
thank you that was alot of help i didnt realize i could do all that with the hand held THROUGH READING THE DIRECTIONS(im not a directions reading kinda guy)i found i can recalibrate my speedo and all kindsa other stuff maybe ill be able to set to tune correctly tomarrow to get the car running right and get it to pass emissions ....
the car was a .50% lean at idle and wot and i didnt like that so i fattened the mix up to .50%rich i would rather have it rich than lean i had noticed it was running out of power at about 3800 so that why i fattened it up but i also had the spark advanced 1% at idle and wot so i left that after i drove it it seem to run so much better.
the only thing was that the tuner did not have a drop down box for obd2 adjustment like the pdf said it did so i was not able to turn the o2s off and the egr off . it also didnt have any parameters for shift points , i dont need shift points cuz im running a stick car but that is some things i have noticed werent in there andthe obd stuff i want to change
does anybody know whats up with that . i dont really feel like calling yohan or mike from diablo right now
The newer versions don't have that option. I totally forgot about that. My version does (7r50d I believe) but the ones after mine don't. Something about the gov't made them take off the option. You'll have to get a custom tune for it. How did you know you were running lean?
