Going boosted!!! Needing help
Old Oct 12, 2009 | 12:04 AM
ramoyer1's Avatar
ramoyer1
Default Going boosted!!! Needing help
Ok my friend gave me a turbo from what i found out it is a Garrett turbo.
here are the stats i want to run this on my stang i am needing to know if it will be enuff or to much for my v6er.
Genuine GARRETT TA3410 Plain Bearing External Wastegated
360 Degree Thrust Bearing
Oil lubricated centersection.
Manufacturer-GARRETT
Model- TA3410
Serial Number -715583 5006
T3 Flange
4'' Inlet
Compressor (A/R) .70
Turbine (A/R) .63
4 Bolt Exhaust flange
External Wastegated
Good for 500- hp
Old Oct 13, 2009 | 08:23 PM
LilRoush's Avatar
LilRoush
Sad to say it, but your buddy gave you the cheap part. You're about $4000 in parts away from having that on your car.
Is the turbo in good shape?
Old Oct 15, 2009 | 12:54 PM
ramoyer1's Avatar
ramoyer1
brand new it has never been used. i mean it is a pretty big turbo.I got turbo headers alrdy made for my car.
Old Oct 15, 2009 | 05:14 PM
LilRoush's Avatar
LilRoush
Shoot, if you have the headers made, you're half way there. Just mount up the turbo and see what you need to run for exhaust piping. Keep it simple and run a single 3" pipe out the back.
Old Oct 15, 2009 | 06:45 PM
ramoyer1's Avatar
ramoyer1
then what else do i need and will the turbo be fine by itself?
I got front mount innercooler,turbo,headers,tuner.
Need fuel pump,boost gauge,wastegate,bov.what else?
GimpyHSHS
Aug 29, 2015 06:30 PM
cedarmn
Aug 28, 2015 09:51 PM
defarmer
Aug 13, 2015 06:40 AM
UINZWAY
S197 Shelby Section
Aug 5, 2015 10:34 PM
