Super Coil Question aka....HELP!
Hey all,
First time posting so be gentle.
So I just spent a pretty penny on some new ignition mods: MSD wire, Good quality spark plugs, and a Accel Supercoil and for the life of me I can't figure out how to install the supercoil. Is anyone running with this? (I've heard it's a really common mod.) And if so can you tell me how you did it? Pictures would be awesome if you were so inclined.
Thanks guys!
Thanks guys!
Here's the Link to it SuperCoil
Notice it says Perfect for stock engines. I know it's not going to give me a whole lot of anything, but I've heard people talk about a better response time while accelerating. So I figured why not.
Its not too bad to put on...Here is what I would do. First, mark every original wire, just out a piece or tape around it.... Ex) Top Left, Top Mid., Top Right, Bottom LEft. etc...then unplug them all, remove the 4 bolts and the eletrical connector, and wa-lah.
And personally I would change the plugs and wires ONE AT A TIME to make sure they go in the right place...
yeah u get that muscle car shake but i bet you cant get over 30 mph
hahaha i had a wire break on me once and flooring it with my mods i could get over 30mph missing one wire. sounded like a$$ too one other important note is make sure you got the right connector style because there's a horizontal and a vertical style, they aren't interchangeable
hey guys thanks for the help.
One of the problems is the mounting. The supercoil has four bolt mounting system while the stock coil is a tripod. Here's some links to explain better.
Stock
Supercoil
Notice also the wiring harness receptor is a different shape...I'm almost fed up with the part. I've heard that this mod is super quick and easy and lots of people have it, so i figured I'd try my luck on the forums. I think I might return it and just take my money with me to Vegas tomorrow.
And I already changed out the sparks and wires, my idle is back to normal now.
Stock
Supercoil
