P0340
Old Oct 27, 2009 | 05:59 PM
deantheking's Avatar
deantheking
Default P0340
So i have a series of problems. Weeks ago what sounded like my belt started squeeking. I replaced the belt, waterpump, and alternator. no change. A couple weeks later it started to make a bad noise when you take it above 2000rpm. It sounds like the engine is miss firing or like the engine is under a heavy load. It also has lost power. There is not check engein light on but i took it to Advanced auto parts and the code p0340 came up so i replaced the cameshaft sensor and no change. What should i do?
Old Oct 28, 2009 | 02:47 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Get a coil. Return the cam sensor, unless you installed it wrong, which is pretty easy to do.
Old Oct 28, 2009 | 11:40 AM
jwog666's Avatar
jwog666
you need to replace the aluminum base that the sensor bolts to. that is what is making the noise. these go bad all the time. the base will have to be marked and the new one installed in the exact same position to keep it in correct time.
Old Oct 28, 2009 | 01:37 PM
deantheking
THE METAL BASE IS WHAT IS CAUSING THE SQUEEKING NOISE? AND SHOULD I JUST TAKE IT SOME WHERE TO GET IT DONE?
Old Oct 28, 2009 | 01:55 PM
deantheking
can i start the car with out the belt on, and if it still make the noise i will know that is the camshaft correct?
Old Oct 28, 2009 | 02:12 PM
deantheking
so i took off the belt and it is still making the squeeking noise. What is the part that i need to replace called?
Old Oct 28, 2009 | 02:26 PM
Synyster06Gates's Avatar
Synyster06Gates
If it's a 5 speed and it sounds like belt squeal/squeaking, it could be your throwout bearing.
Old Oct 28, 2009 | 02:55 PM
jwog666's Avatar
jwog666
its called the camshaft sensor syncronizer, if it was a 5 speed and the throwout was making noise pushing in the clutch pedal will make the noise change or go away all together. if you dont have alot of experience working on cars i would take it to your mechanic.
Old Oct 28, 2009 | 09:06 PM
deantheking
It was camshaft sensor syncronizer, cost 65 bucks and 80 to have it put in. Thank you very much jwog666.
Old Oct 29, 2009 | 02:27 PM
jwog666's Avatar
jwog666
Smile
no problem
Carcrazycorey1
May 15, 2013 09:52 PM
Stealthrida
May 3, 2010 08:53 PM
s7stang
Jul 22, 2009 11:28 AM
cheftjpeck
Apr 4, 2008 02:06 PM
cheftjpeck
Aug 21, 2007 11:18 PM
