hey i need some opinion
Gears and a limited slip differential is the best, but on a 99+ you need a tuner to correct the speedometer.
So in short, here's how I'd do things:
K&N drop in filter & remove (or cut, your choice) the air silencer
True Dual Exhaust (your choice, but go with an H-Pipe or straights)
Tuner
Gears/Limited Slip Differential
Supercharger 8-10 PSI (make sure it comes complete with the fuel set, if not you'll also need a 255lb hr fuel pump, 42lb injectors, MSD dual control ignition box, and fuel management unit aka FMU)
After that, if it's still not what you want get a 65mm throttle body, port match your upper and lower intakes, get a set of ported heads (or have a shop port yours and do a valve job), get new valves, and a custom ground cam.
Tuner
Performance doesn't come cheap.
How far do you want to go with your car? If you are looking to make a car that is actually considered fast then you'll want to supercharge it.
Cheaper mods like bolt on's, CAI, exhaust, gears, aren't going to barely do squat for your car.
