Improving Exhaust
Dont waste $$ on bbk Shorties, they don't give you and advances performance-wise, they're basically just "pretty" stock headers.
i Got my ceramics + a custom x pipe( made by dr. gas auto exhaust, that i didn't use and im trying to sell) for $200....
these threads just bring bad memories..
Same, haven't bought one, yeah I got about 2 years of "saved luck" when I turn 20, Jan 3rd. lolol
Brent4 do you have an exhaust vid?
these threads just bring bad memories..Brent4 do you have an exhaust vid?
Yep ive gota crappy vid taking for my POS phone somewhere on youtube. Ive been working the night shift, so that means i have to sleep during the day but I gota get mo better pics and vids up here sometime.
I want to dyno before and after shorties because they look like they do flow a little better than stock. I just don't want to waste the money but I want to do it just to find out. Complete same exhaust just header swap and dyno before and after. I might do it one of these days. If you look at these two pictures, the stock manifolds don't really have a collector they dump into the first primary and kind of use that as a collector. The primaries are much shorter than on the BBK's which actually have a collector and keep the primaries separate. I'm not saying it would be enough to justify spending the same money as you could on lt's I just want to find out.
See what I mean....
Stock
BBK's
See what I mean....
Stock
BBK's
ok the best thing to do is get an off road X pipe and take 2 of the cats off if u realy have 4.
if you can afford it summitracing.com has pacesetter long tubes for $150
off road x pipe can be anywhere from 10 to 160 dollars. a universal x is cheap and since u already have dual exhaust i would suggest it. all x pipes are the same so cheaper the better. go to ebay for a universal.
the full size would be a wast of money.
the flow masters should be fine but if its still not loud enough get glass packs
I know everyone says that, but if I could afford the shorties I want to swap do a before and after dyno to actually see some results. No one has even posted a dyno of this, just shorties don't do anything so I want to actually find out for myself.
