Welp do you have cats on the car? Your rear 02 sensors would be throwing you off because there are no cats.
Justin can turn off the rear o2 sensors via the SCT so you dont have this problem.
O_o that would make quite a noise under the hood if it wasnt connected.
The EGR can get caked up really badly with carbon, you can clean this out or buy a new one.
My EGR is fine. While changing my passenger side header, we broke the EGR tube so I've pieced together my own temporary delete kit. I'm getting a code because of that. My o2 sensors seem to be fine, but how can I check?
Deleting the EGR believe it or not, could be causing the problem because the sensor is still looking for the data the egr isn't sending, just a thought.
Possibly. I can also see it being the problem since no exhaust gas is being recirculated into the cylinders, it's all fresh, cold air... I got a replacement tube that is going on tomorrow, so all should be good!
