Rod Bearing
Old Nov 21, 2009 | 01:30 PM
akp20032004's Avatar
akp20032004
Default Rod Bearing
It's bad on cylinder 6. Will it be easy to just drop the oil pan and go like that?
Old Nov 22, 2009 | 09:37 PM
straight6racing's Avatar
straight6racing
in order to drop the oil pan you will have to drop the whole k-member to get the oil pan off. i would suggest just yanking the engine to do it.
Old Nov 22, 2009 | 11:49 PM
neo8222's Avatar
neo8222
when i was under my car (vert) i had the k brace off and it didn't appear to have any obstructions blocking the pan from coming off
Old Nov 23, 2009 | 11:09 AM
straight6racing
you have to keep in mind that the pan has to drop quite a ways to clear the mains and oil pickup.
Old Nov 23, 2009 | 12:57 PM
neo8222's Avatar
neo8222
yeah i know that, but when i was under mine (granted i wasnt looking to see if i had clearance, just a passing glance while working) it looked like it would fall to the ground if i removed the bolts
Old Nov 23, 2009 | 01:08 PM
neo8222's Avatar
neo8222
i just read my book and to remove the oil pan, it is infact a tiem consuming process but the only specialty tool you need is a engine support fixture, just because the engine mounts have to be unbolted
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
UrS4
Sep 30, 2015 10:13 AM
mustangheaven
Sep 29, 2015 11:00 AM
