Tuners/Programmers
Old Dec 18, 2009 | 09:32 AM
Noxy's Avatar
Noxy
Default Tuners/Programmers
Ok guys. I spend a lot of time reading about mustangs and the things you can do to them.
But I'm still slightly lost on this whole tuning thing...
Can someone PLEASE explain to me when/why you would have to buy a custom tuner? Also what happens when you do some bigger mods to your engine and you don't tune it? ~
Be nice and use minimal sarcasm...
Old Dec 18, 2009 | 09:39 AM
Shaunmac9128's Avatar
Shaunmac9128
Tuners are very a good starting mod if your an automatic. It re-calibrates the engine with the preset tune in it and adds roughly 5-10hp on a stock or slightly stock engine. With it you can adjust timing, your a/f ration, remove the speed limiter, adjust the rpm limiter and adjust the shift points and firmness and possibly a few other things I'm forgetting. They really help with the shifting on an automatic by making the shifts firmer, which is one of the reasons they do not do as much for manuals. It will really wake up your car and it will pull harder from 0 all the way to 120. Also if you start doing more serious mods like heads/intake/cams I personally thing you should get a dyno-tune which can be done through your tuner, and tuning software at a shop that works with it. Justin from vmptuing.com will also set you up with a custom tune for your mods for $60 if you use an SCT, which is probably good for a few more hp than a canned tune (the ones that come pre-programmed) not positive though. Also if you give him your a/f (air/fuel) ratio and some other information throughout the entire rpm range from a dyno pull he could probably go a lot more in-depth with the tuning and give you a more precise tune. Thats about the extent of my knowledge lol.
Old Dec 18, 2009 | 09:46 AM
Polishgonewild's Avatar
Polishgonewild
Thanks that helped me too
Old Dec 18, 2009 | 09:58 AM
Shaunmac9128
No problem. Maybe someone can chime in and go a little more indepth for you guys. If you have any more specific questions let me know, I'll see if I can help haha.
Old Dec 18, 2009 | 09:59 AM
Noxy's Avatar
Noxy
That was a good first reply; thank you.
Old Dec 19, 2009 | 02:35 AM
Azrael's Avatar
Azrael
Just a few additions: tuners are absolutely REQUIRED when putting in new gears, cams, superchargers/turbos, and any other engine/drivetrain mod you can think of that costs more than about $200. I've been driving with 3.73 gears now and no tune for about 3 months (because I was too cheap to get one at the same time as the rest of my parts). My speedometer is completely incorrect, and I'll be getting the M112 supercharger eventually. When I do that, I will have no choice.
Old Dec 19, 2009 | 08:22 AM
Chanda44's Avatar
Chanda44
Any Differences between SCT tuners and Diablosport tuners? Pros or Cons to either or both of them?
Old Dec 19, 2009 | 08:49 AM
Shaunmac9128
Thats not entirely true. I don't want people to take that too literally because there are multiple $200-300 engine/drivetrain mods I can think of that don't require a tune. Its more when you get into the engine or f/i that it requires a tuner so you can have the engine tuned properly. And they also sell a speedo corrector for certain years for like $100 so it saves you $300 over a tuner. But yeah you will need a dyno tune when you get the M112 no doubt.
SCT has a faster load time, trust me I have a diablo and its slow as hell. Plus with the new 4.0's I'm pretty sure breenspeed is popular because they sell good custom tunes. Not as popular for our cars. Once again, check the 4.0 tech section for more help.
Old Dec 20, 2009 | 02:23 AM
rfcsoulja's Avatar
rfcsoulja
SCT has more companys who provide good e-mail tunes.
Old Dec 20, 2009 | 02:25 AM
neo8222's Avatar
neo8222
im the black sheep i prefer my delta force tuning sniper kit.
