SSM Kit installed, now get P0430
id say remove the belt and spin water pump by hand and try to wiggle side to side, then start the car for a short time to determine accessory system or engine. no noise with belt off means engine good and it's an accessory. (also do a compression test because a clogged cat can actually burn a valve and cause major damage.)
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
