Quick hid help?!
Old Jan 7, 2010 | 03:49 PM
Shaunmac9128's Avatar
Shaunmac9128
Default Quick hid help?!
So I installed my hids and they look great but short out when I go over bumps so now I'm an hour from home with no lights :/ I need some help, ideas?
Old Jan 7, 2010 | 04:20 PM
Shaunmac9128
Well they're staying ok now but I'm still a little concerned. I'll check all the connections tomorrow when it's light.
Old Jan 7, 2010 | 04:39 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
It's definately a loose connection. Something else i recommend is insuring as good a ground as possible.
Old Jan 7, 2010 | 10:48 PM
Shaunmac9128
Okay, so I just got home and everything went fine. However I pulled in the driveway and went to lock the car (with remote) and nothing happened so I'm like hmm. Then I try to lock it with the lock button on the drivers door, nothing, I think I had no electrical power. Why I don't know so I'm going to have to figure it out tomorrow.
Old Jan 7, 2010 | 11:20 PM
RyansQuick6
Reverse Gear Member
check your negative battery terminal. If you grounded directly to it, where did you put the wire? Take a pic and post it. I have a pretty good idea of how you boogered it, and you're gonna feel like a total nubtard when you realize how simple it is lol
It happens to all of us sometimes.
Old Jan 7, 2010 | 11:23 PM
Shaunmac9128
Nah I didn't ground to the negative terminal, I used some random bolts on the car not connected to anything electrical, is that bad? I'll post a pic in the am.
Old Jan 7, 2010 | 11:27 PM
TurtleSLow's Avatar
TurtleSLow
you had to run a ground with your hid kit?
Old Jan 8, 2010 | 12:42 AM
RyansQuick6
Reverse Gear Member
ground it to the battery.
It's always good to run an additional ground, even with stock headlights. For some odd reason those are weak points on a lot of cars.
Old Jan 8, 2010 | 12:49 AM
TurtleSLow's Avatar
TurtleSLow
damn didnt know that.. well i just plugged my kit in and off i went. no problems
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
kawiguy827
Sep 22, 2015 10:52 AM
